Whirring/Grinding sound when cold
Hello Everyone!
I have a 2000 XK8 w/106K miles. When cold, if I tap the gas just a little too much, the engine makes this whirring, rattling grinding sound off the line, which continues through the shifting until reaching speed. At speed it stops, and after getting completely heat soaked it stops during further shifting and sometimes off the line.
I had the belt replaced and tensioner adjusted a while back and that helped, but alas it has regressed. Had some pulleys replaced w/no effect.
I understand that the XK8 used to come with nylon pulleys, if so would it help to go back to those? If not, what could the problem and solution be?
Russ
Russ
As a 2000 model the exhaust camchain tensioners on each cylinder bank come to mind straightaway. I suggest you take the cam covers off for inspection asap if not before. Engines are wrecked when these let go. If they haven't been replaced, its time to replace them.
Interesting sound !! First try this when the car is cold like after its been sitting overnight, open the hood/bonet and have some one start the engine. Stick you head under the hood towards the from of the engine.
Is the sound a rattle or squeal ?
1/ If its a rattle/grind and is coming from the front of the cam cover left or right its probably your secondary tensioners. Have you had those changed ? as your model has the 1st generation that will go around 100K. These can be changed parts $210 (eBay) and takes 3-4hrs for a DIYer. If noise is front of engine left/right and not at the top could be your primary tensioners in which case parts are $650 (primary/secondary chains tensioners, gaskets e.t.c) and 10-12 hrs labor
2/ If its a squeal and comes from the front of the engine and seems to happen every revolution of the main belt then it probably your belt. Note the belts are self adjusting. If belt change it to an OEM belt NOT jaguar brand as theirs do squeal.
to OP, if not your tensioners, could be your idler pulley, those bearings do go out. Also, check your power steering fluid, my system had a leak, and over time, my squeal at start got progressively worse (thought was the idler, then tensioner) eventually got so low, that the sound lasted almost the entire time while running, until my mechanic found the ruptured line over by the RF fender, saw the fluid all over my sway bar bushing.
+1 on getting your secondary tensioners checked, and if the old style, replace immediately. Have you seen images on this forum of the broken timing chains? There's stories of jumped timing wreaking havoc, tensioner pieces ending up in places where they shoudln't be, etc. It enough to scare you to death.
Thanks everyone. I went to the shop and they agree with Fraser that it's the valve tensioners and possibly a broken chain rail as well. Will probably open it up next week and after evaluation, replace everything except the coils as they seem fine right now.
Sorry about the multiple posts!
Let us know how much they charge to change primary and secondary tensioners and chains. Should be interesting I know the parts on eBay (there's a kit for this ) is around $650.
http://cgi.ebay.com/ebaymotors/JAGUA...Q5fAccessories
As for belts I got mine from Kragen $130 for main and supercharger belts. On XKR there is a TSB and kit for the supercharger belt squeal. Mine has squealed when cold from the day I bought it in 2004. Jag replaced the belt but still squealed. When I changed the belt to a non Jaguar belt (goodyear gatorback I think) squeal has gone.
42Ajd
12-30-2015 09:45 AM
jazzman20014
10-26-2015 04:15 PM
