Why is the expansion hose a hard pipe?
Old 09-06-2020 | 06:26 PM
Stamford's Avatar
Default Why is the expansion hose a hard pipe?
I managed to break this expansion hose, so I'm temporarily replacing it with a length of rubber coolant hose.
My question is why is this hose actually a hard plastic pipe? Will using the rubber hose cause any issues like collapsing or anything else?
Thanks!
Old 09-06-2020 | 06:53 PM
RJ237's Avatar
I replaced mine with fuel line a couple of years ago, no problems.
Stamford (09-06-2020)
Old 09-06-2020 | 08:13 PM
giandanielxk8's Avatar
I did the same and never looked back.
Old 09-06-2020 | 10:32 PM
Johnken's Avatar
Same here.
Stamford (09-07-2020)
Old 09-07-2020 | 06:07 AM
Jon89's Avatar
Me too. Way back in November 2014 when I had to replace the coolant outlet pipe assembly....
Old 09-07-2020 | 08:09 AM
CorStevens's Avatar
it was made out of hard plastic because it looked nicer that way. It was rigid and followed a neat path with minimal support. Technically a metal pipe coated with a glossy surface would have the same result, but costs more. Plastic is cheap too.
The following 2 users liked this post by CorStevens:
DavidYau (09-07-2020), Stamford (09-07-2020)
Old 09-07-2020 | 10:28 AM
Stamford's Avatar
Makes sense. I was so proud I didn't break any of the breather hoses when removing the intake manifold, But when I replaced the manifold I didn't realize the expansion hose was trapped under the edge and snapped it in two. Stupid!
Old 09-08-2020 | 07:57 AM
fmertz's Avatar
FWIW, I replaced this plastic pipe a while back with a section of flexible hose "from the garage" as everyone else did. A while later, that hose had turned stiff, brittle and leaky. Must have been the wrong kind. I ended up replacing it with the Jaguar part, figuring it was cheaper than a tow...
Stamford (09-08-2020)
Old 09-08-2020 | 08:53 AM
Jon89's Avatar
Yep, some rubber hoses are more durable than others. Transmission hose may be the best option for this particular application. I believe that is what I purchased for this replacement back in late 2014 and it has held up relatively well. That hose location certainly bakes there at the top of the engine bay....
Old 09-09-2020 | 08:17 PM
stu46h's Avatar
Same here.
MussieRon
16
04-07-2020 08:49 PM
Z07Brandon
02-29-2020 08:10 AM
vdpnyc
12-04-2016 09:48 AM
34by151
03-13-2015 10:27 PM
Quick Reply: Why is the expansion hose a hard pipe?
