Why is my car still drivable?
As mentioned, make sure your battery is fully charged. Clear the codes and see which ones return after a short drive. Hopefully you will have a much shorter list.
Lots of codes can be set from previous incidents and service which are not relevant any more and if they are not cleared they will continue to accumulate.
So my car threw a few fault codes. Would anyone care to chime in?
P0420 - Cat efficiency
P1260 - Security input
P1571 - brake switch
P1582 - flight recorder data ?????
P0305 -
P1316 -
P0102 - air flow circuit low
P0112 - intake air temp low
C1446 - brake switch
C1516 -
U1041 - vehicle speed ????? [was I going too fast?]
B1595 - illegal input code ?????
U2012 -
B2334 -
B2368 -
B1858
B1234 - mirror switch
B2323 - mirror
B2327 - mirror
U1135 - ignition
B1236 - door window glass
U1135 - ignition
B2323 -
B2327 -
U1041 - ["unknown fault code"]
U1135 - ignition
U1135 - ignition
B2295[29] -
P0305 -
P1316 -
C1516 -
U2012 -
B2334 -
B2368 -
B1858
B2323 - mirror
B2327 - mirror
U1135 - ignition
U1135 - ignition
B2323 -
B2327 -
U1135 - ignition
U1135 - ignition
B2295[29] -
Anyone know the others?
The car runs well. Only lights are the "Check Rear Lights / Cruise Not Available" and an intermittent airbag light.
Don't waste your and our time on historical codes that may mean nothing. Codes could have been unintentionally set during earlier repair work. Clear the codes and see which come back, then we will help you with what remains.
Nati
05-16-2020 08:30 AM
SingBlueSilver
08-27-2015 02:20 PM
Vector
US Lower Atlantic
08-26-2015 05:36 AM
