Will the 4.2 XKR
Hi
No harm done, in my hand book, page 6-18. Fascia fuse box passenger side
Fuse 14 cigar lighter ......
I don`t know where the fascia fuse box is yet..he he
These cars should be like boats with Port & starboard.
thanks for answering
bob
bt_bob1 (01-20-2014)
Lol. Very nice.
But I will admit to confusion when others use driver side, passenger side, with abandon. And then there're the near side and off side expressions, like watching a football match. So port and starboard, left and right, are all equal in my book.
#28
That`s why a long long time ago sailors started using Port & Starboard and Aircraft as well..
Have fun
cheers bob
You're citing local people using more or less slang. They probably also know it's slang and what the standard terminology is but just continue with their slang. But have a look at the workshop manual and you won't find offside and nearside.
#30
That's like saying if you stand facing the rear of a ship that port & starboard are swapped. They're not. Nor are car directions. In both cases you just need to know what you're talking about. You do realise that similar to what you put many people on board ship won't know which is port and which starboard...
#31
#32
#33
Another newbie question ..could you drain about 2 pints of oil out of your AT drain hole and just top it up with fresh ?if you did this say once a month eventually you would refresh most of your oil over a year...
You could gain access by just jacking up one side of the car on the drive.
It is said that the quantity of oil in the AT is critical and you would need to do this with the engine running otherwise oil would also come out of the fill hole, so if you are going to that bother why not just do it as per the recommended procedure. I plan to do the oil change for 3 years on the trot then forget about it for the following 5 years and then repeat.
#34
#35
#36
My immaculate 2004 XKR Cigar lighter worked but the phone charger would not connect. I noticed the center connector in the bottom of the female end was brown. The lighter looked to have never touched a cigarette or cigar so just normal air oxidation. I touched my dremel tool it it fir a second or 2 and viola phone charger instantly lit up and works like a champ.
#37
