Will the 4.2 XKR
Old 01-20-2014, 12:23 PM
ccfulton's Avatar
Received 1,108 Likes on 764 Posts
Sorry, my mistake.
I was looking at the wiring diagram and the lines to the driver/passenger boxes are drawn as dotted with a note about RHD/LHD. I assumed that this meant that the wiring harness was reversed between the two.
Old 01-20-2014, 12:35 PM
bt_bob1's Avatar
Smile
Originally Posted by ccfulton
Sorry, my mistake.
Hi
No harm done, in my hand book, page 6-18. Fascia fuse box passenger side
Fuse 14 cigar lighter ......
I don`t know where the fascia fuse box is yet..he he
These cars should be like boats with Port & starboard.
thanks for answering
bob
Old 01-20-2014, 01:08 PM
ccfulton's Avatar
Open the door and on the side of the dash is an access panel. Sort of a triangular shape.
bt_bob1 (01-20-2014)
Old 01-20-2014, 02:35 PM
JagV8's Avatar
Received 4,551 Likes on 3,958 Posts
They are: cars use left & right. Standardised many years ago.
Old 01-20-2014, 03:10 PM
bt_bob1's Avatar
All depends from what end your looking at.
And they have the wheel on the wrong side over the pond ....
Old 01-20-2014, 06:20 PM
GGG is offline
Received 16,867 Likes on 12,186 Posts
LH and RH are always taken from the rear of the vehicle looking forwards.
Hence LHD and RHD perfectly describes the location of the steering wheel.
Old 01-20-2014, 08:40 PM
Steve8's Avatar
Lol. Very nice.
But I will admit to confusion when others use driver side, passenger side, with abandon. And then there're the near side and off side expressions, like watching a football match. So port and starboard, left and right, are all equal in my book.
  #28
Old 01-21-2014, 03:09 AM
bt_bob1's Avatar
I know, but looking into an engine bay if you say its on the left hand side. It would be to your right!!!!!
That`s why a long long time ago sailors started using Port & Starboard and Aircraft as well..
Have fun
cheers bob
Old 01-21-2014, 03:21 AM
JagV8's Avatar
Originally Posted by Steve8
Lol. Very nice.
Others may say those things but left & right ARE standardised. See SAE, ISO etc.
You're citing local people using more or less slang. They probably also know it's slang and what the standard terminology is but just continue with their slang. But have a look at the workshop manual and you won't find offside and nearside.
  #30
Old 01-21-2014, 03:24 AM
JagV8's Avatar
Have fun
cheers bob
That's like saying if you stand facing the rear of a ship that port & starboard are swapped. They're not. Nor are car directions. In both cases you just need to know what you're talking about. You do realise that similar to what you put many people on board ship won't know which is port and which starboard...
  #31
Old 01-21-2014, 03:31 AM
bt_bob1's Avatar
Its not my fault that people are navagationly challenged .
  #32
Old 01-21-2014, 04:02 AM
bt_bob1's Avatar
Another newbie question ..could you drain about 2 pints of oil out of your AT drain hole and just top it up with fresh ?if you did this say once a month eventually you would refresh most of your oil over a year...
You could gain access by just jacking up one side of the car on the drive.
  #33
Old 01-21-2014, 05:33 AM
RaceDiagnostics's Avatar
It is said that the quantity of oil in the AT is critical and you would need to do this with the engine running otherwise oil would also come out of the fill hole, so if you are going to that bother why not just do it as per the recommended procedure. I plan to do the oil change for 3 years on the trot then forget about it for the following 5 years and then repeat.
  #34
Old 01-21-2014, 08:44 AM
Jon89's Avatar
Received 4,392 Likes on 2,868 Posts
Agreed. This is a complicated, messy, potentially dangerous procedure (if your skin comes in contact with the hot exhaust pipes) so if you elect to do any ATF draining, it is far better to just go ahead with the complete drain-and-fill procedure from start to finish....
  #35
Old 01-22-2014, 10:41 AM
bt_bob1's Avatar
NEXT
Next new minor problem!!!!! The yellow/orange Abs warning light showed today. I stopped the car switched it off, pressed the brake pedal, bit spongy, started the engine and light was off with a firm pedal ?
  #36
Old 02-19-2022, 08:46 AM
Markmbaha1's Avatar
I am absolutely delighted with the car just a few niggles .One of which, is cigarette lighter does not work ,I don`t smoke but want to insert a solar panel to keep the battery charged ,where the best place to start looking?
My immaculate 2004 XKR Cigar lighter worked but the phone charger would not connect. I noticed the center connector in the bottom of the female end was brown. The lighter looked to have never touched a cigarette or cigar so just normal air oxidation. I touched my dremel tool it it fir a second or 2 and viola phone charger instantly lit up and works like a champ.
  #37
Old 02-19-2022, 11:32 AM
JagV8's Avatar
Check fuse(s)...
FrickenJag
09-25-2016 08:00 PM
duecedriver
12-25-2015 11:47 AM
tassiejag
09-24-2015 08:43 PM
hhv00586
09-18-2015 08:59 AM
simongulliver
09-16-2015 03:40 AM
Quick Reply: Will the 4.2 XKR
