Will not disengage from "Park"
On my home today my hand accidently pushed the shift lever from Drive to Park and back to Drive while the car was going about 20mph. Nothing seemed to happen at the time but when I went to pull the car out of the driveway, the shift lever stays stuck in Park. Also my tilt/telescoping wheel doesn't seem to work.
Any ideas? Is there some sort of reset like disconnecting the battery and reconnecting it? Can it be as simple as a fuse or did I screw the pooch on this one. I just purchased my 1997 XK8 last week!
JBD
JBD
Had this happen to me once from cold when trying to pull out of my garage - shift wouldn't move out of park and I couldn't hear the normal click when depressing the brake pedal. Did a hard reset and all was fine - never happened since(18 months ago).However, I did have to replace the battery not long after and didn't have any of the normal window reset problems prior to the battery failing. Just a thought and simple to try.
Now you've got past that issue, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
If you're new to the J-gate I guess it could happen if you "shift" on the right side and not the left. I once managed to throw my 6.0 XJ-S into Reverse in the rain one night. I wish wish wish I had a video of it. Did a full 360 on a city street and amazingly hit nothing except a moveable bus stop sign I sideswiped. $1400 for bodywork and $5.95 for some new Jockeys.
Jag4me2
Audio/Visual Electronics
10-05-2012 09:37 AM
