Window cycling when top is lowered/raised
Old 11-11-2019 | 09:00 AM
SamtheSham's Avatar
Default Window cycling when top is lowered/raised
When I lower the top on my '06 XK, The front windows remain up after the top is fully down and seated. I usually then use the 'up' side of the switch to lower the door windows. When raising the top, all windows move into place as desired. I have noticed lately that after I raised the top, on occasion the passenger window will lower randomly without any action on my part, and must be raised with the passenger door switch. My driver's door switch will not activate the window. After it is up, I can use either switch to raise/lower the window.
Yesterday on lowering the top, I tried using just the driver's switches to lower the windows after the top was fully down. Only the driver's window went down. I had to use the passenger switch to lower the passenger window.
I have tried the 'Full down, full back up' reset attempt a couple of times to see if that is the problem, but this described condition/action remains.
Any ideas as to the problem, or is this just another anomaly of our 'Electric' cars?
doc
10-13-2015 10:16 PM
oldmots
08-09-2014 01:17 PM
carmat731
02-13-2013 03:40 PM
RichmondXK
05-22-2011 01:06 PM
Skid Mark
09-03-2010 10:54 PM
Quick Reply: Window cycling when top is lowered/raised
