Window Issue
Window Issue
I have an odd issue with the passenger side window when opening the door.
Usually the window goes down about 1/4" and stays there until the door is closed and then goes back up. However now my window goes down slightly when the door is opened, but immediately goes back up while the door is still open. This makes shutting the door impossible because the window glass interferes. I have to lower the window via the button and then close the door and then raise the window. I have reset both windows via the procedure numerous times, but it still shows this behavior. 2003 XKR convertible. Any ideas?
JagRag (05-27-2016)
Does the car know the door is open (micro switch in latch)? This happened to me with switch stuck. Neither the puddle lights nor the red passenger door open displayed when door was open. So it was as if I touched door handle with door closed.
It's a bit more of a pain in the neck to fix switch vs.Batterry so I hope it is the easy one.
JagRag (05-27-2016)
I agree with Johnken it is very likely the microswitch in the door latch assy that detects that the door is open. If there is no door open message on the speedo display and no interior light on when you open the door, that is further confirmation.
Part number is C2N1908 and it is and is around 30 bucks.
JagRag (05-27-2016)
JagRag (06-04-2016)
Jon89
06-07-2016 06:20 AM
RAT572762
General Tech Help
05-24-2016 06:30 PM
