window problem 04 xkr coupe
Just bought got the above, noticed that when you open the passanger door the window drops down to clear that's working ,but, if you keep opening and closing the widow keeps dropping and does return to up position when closed like drivers side.
Any ideas?
Bob
Any ideas?
Bob
If you don't have an owner's manual, try the FAQ thread at the top of this sub-forum. There is a link in there to download one.
You simply need to reprogram your windows, this is required after every battery disconnect, or one of the first signs your battery is dying.
Sit in the car, close the door. Hold the window switch down till the window drops all the way, then hold...you'll hear a click in about 3 seconds. Now roll the window up and hold again at the top...another click. That window is now programmed.
Beardy
09-18-2015 10:00 AM
