window washer pump
window washer pump
First post ,I dont know the rules ,anyway I have a 1997 xk8 ,and unfortunately I have a problem with my window washers the pump is not getting any electricity I have a friend who is a part time mechanic But he doesn't know a lot about Jaguars he's had a look but he has no idea what he can do to repair the problem ,can anyone out there help me please.
macjag1745 (08-29-2017)
You may not know the rules but you found the right place first time to post your question which is more than many newbies manage to do.
Pump not getting electricity - is this confirmed by taking off the wheelarch liner and checking the harness connection to the pump in the screenwash reservoir?
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some information about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Windscreen washer no electricity
Welcome to the forum macjag1745,
yes I think he tried that ,he also informed me that he had checked all the fuses in the car
The following 2 users liked this post by GGG:
macjag1745 (08-29-2017),
Orthodixie (08-29-2017)
Received 2,434 Likes
Sorry - brain freeze. What I meant to say was 'do the wipers cycle when you press the button on the end of the stalk'
There's a similar thread here by spuddio that he tracked down to F7 (15A) in the drivers facia fusebox, but he had other issues also:
https://www.jaguarforums.com/forum/x...30/#post680469
Failing that, it's a case of tracing the wiring from the pump back through connector LF1 to the body processor module. One other possibility is the grounding to the stud LF1AR (shown in GGG's diagram). JTIS shows it adjacent to the RHS headlamp.
macjag1745 (08-30-2017)
windscreen washer pump
I have checked the number 7 fuse 15 amp driver's side facia it's ok I also checked the fuses in the engine compartment number 7 30 amp its ok as well ,neither the windscreen washer or the headlamp washer is working ,the wipers seem to function correctly,even when I press on the button at the end of the stalk they cycle as they should do but als no liquid to be seen anywhere, as we say in France "a l'aide" I don't know how to check the relay "powerwash " how does one check a relay?
You know, something just occurred to me. I've seen several wires solder joints come lose and disconnect with age on the end of the headlight stalk. I would imagine the price of a new wiper switch is just as shocking as the headlight is.
Given that you may want to pull the steering wheel and have a look. Ok stick with me here: I was about to delete this suggestion thinking if the wipers cycle, the momentary switch is sending a signal to start the was cycle. Who would design a switch with 2 separate wires to start this automated cycle?
I am on a phone without glasses so can't review thediagrams. Since this event (squirt, wipe, wait wipe) is a coordinated layered event it must be managed by a module.
I think we may have just proved your switch and it's wires are ok by the fact that the wipers energize. I don't see how the switch would have 2 separate wires but do check the diagram to be sure.
My next step would be to read "trigger" voltage at the relay for the pump while someone presses the button. If no voltage present, provide some to ensure the pump works.
John
John
macjag1745 (09-02-2017)
John
John
