Windows on convertible not closing properly
Hi
Normally the windows should seal into the hood when you shut your door, well sometimes they do and othertimes they don't?
Also they go up before i close the door so the glass is too high to go under the hood. I find if i send them all the way down and back up they work sometimes.
Whats the problem??
Whats the problem??
Window Adjustment
XK8Rupes - The window movement up and down can be self adjusted by holding the up and down switches for approx. 3-5 seconds at the up and down positions.
If you have already performed this task, go to FAQ in the thread section, scroll down to Interior/Mechanical Issues, go to Adjustment of Window using regulator stop - WITH VIDEO - in which Rev Sam has produced an excellent video on how to remove the door panel and adjust the window regulator mechanism.
IcallherAJ (12-14-2010)
Received 2,192 Likes
99xk8guy
06-05-2023 06:28 AM
aholbro1
08-05-2021 05:02 AM
Aus V8S
11-13-2015 11:01 AM
