Windows frequently out of sync - RESOLVED
![Smile](https://www.jaguarforums.com/forum/images/icons/icon7.gif)
Almost everytime I get in my 2000 XK8 conv. the windows have to be resynced. Easy to do but this hasn't been the problem before except when the car sat for an extended period. It is not sitting now. It is driven almost daily.
I am suspecious that it might be the battery showing it's age. Except for the windows everything else works fine. Not sure how old the battery is but pretty old.
Any other things that could cause this?
Last edited by GGG; 11-03-2012 at 02:28 PM. Reason: Add 'RESOLVED' to thread title
EZDriver (10-22-2012)
EZDriver (10-24-2012)
Window memory is often lost when the voltage goes below 10.5v and this could take place after the car has been sitting for a few days or just after an engine start. If you checked it with a volt meter that is not a good test. Take the car to Sears, AutoZone, :PepBoys or Advance Auto and get them to test it under load.
EZDriver (10-25-2012)
Starting the engine is enough to pull the voltage down enough to affect window memory. That happens to me a lot. Always due to a marginal battery and/or low state of charge. I added some solar panel boosters, but that wasn't enough. Now I've started installing battery disconnect switches to all my batteries if I'm going to park them a few days. Of course, that guarantees window setting is lost, trip computer zeros, and clock stops. Having a marginal battery was OK on simpler cars, but not on an XK8. In addition, I top up charge my batteries on occasion if I'm not driving the car enough.
SeaRay (11-04-2012)
I was having the same issue, and I posted a thread about it a few months ago. Someone told me to check the battery voltage after the car had been sitting overnight. As I recall, 12.5V was the tipping point. My battery read 12.6V. I replaced it (Jaguar branded, so likely original and 10 years old), and the window problem was solved.
Thanks Graham.
GGG (11-03-2012)
blackenedindustries
09-30-2015 10:17 AM
