windows not going up when I close the door
Old 06-24-2019, 01:26 PM
stu46h's Avatar
When my windows would dip down but not return up, I had no other electrical problems with the car.
I read on this forum that a new battery would probably fix the problem.
It sounded a bit ridiculous, as I had no problem starting the car.
I did replace the battery since I figured that after 14 years it owed me nothing and it solved the problem.
  #42
Old 06-24-2019, 01:30 PM
Marqymarquis's Avatar
Default Battery
Hi Stu,
Thanks for your reply - but as I’ve already said, my battery was fitted new very recenty.
regards
  #43
Old 01-14-2021, 11:03 AM
wayne warnica's Avatar
Default Replacement battery suggestion
Originally Posted by Tommymor
My car sat for a while and after charging the battery and starting it up, i had the same problem with the windows. The reset instructions solved it! What a great resource this forum is!
Find your local battery distributor. Ask for a “Second”. The only thing that makes it a second is some cosmetic blemish on the case. Price will be less than half of factory original. More importantly life will be the same. Have been using a “second” for seven years with no memory issues (not counting my own.....)
BLACCAT
  #44
Old 09-20-2023, 01:18 AM
tiger351w's Avatar
Eleven years later you advice is still helping new owners. Thanks
  #45
Old 12-06-2023, 05:12 PM
BillT's Avatar
You guys are awesome! Another mystery solved on my 2002 XKR conv. Thanks so much. Bill
jantech
03-25-2016 11:26 AM
Pdytat
03-19-2014 09:42 PM
Burdedw
06-24-2013 09:53 AM
OhioXK
06-26-2012 01:45 PM
jagxkrtoofast
06-11-2012 07:11 PM
Quick Reply: windows not going up when I close the door
