Windows open but top will not
Old 04-19-2015, 06:50 AM
Lifts's Avatar
Default Windows open but top will not
all windows go up and down with the top switch but the topwill not open. Sounds like no voltage going to the pump. It did this once lastyear and i ran the windows up and then back down and it worked fine. Any ideas?thanks in advance.
Old 04-20-2015, 07:39 AM
stetson1's Avatar
once the windows are down, what happens? does the top release from the top rail? is there any sound at all, like it wants or should be going down or just silence?
Old 04-20-2015, 07:44 AM
WhiteXKR's Avatar
Received 2,989 Likes on 2,125 Posts
Have you checked that the pump fluid level is between the two embossed lines on the tank?
Old 04-21-2015, 06:36 AM
Lifts's Avatar
just silence. The fluid is fine. Once i found the 2 roof relaysi switched them and it is working (for now)
99xk8guy
05-28-2024 09:36 PM
99xk8guy
06-05-2023 06:28 AM
aholbro1
08-05-2021 05:02 AM
GordoCatCar
01-02-2017 01:10 PM
1100me
09-07-2015 06:26 AM
Quick Reply: Windows open but top will not
