Windshield washer not working
Some Assumptions:
Wipers are working through the various intervals? The washer button at the end of the wiper lever (wash/wipe stalk) is part of the switch pack operating the wiper operations; therefore, hopefully the button at the end of the stalk is operational.
There is a fluid level sensor in the washer reservoir which will indicate a low fluid level, and should give you a warning light. Unless malfunctioning, as you state, the reservoir has fluid, and the washer should be working.
When the button is depressed, the pump in the reservoir should be pumping fluid through the tubing to the spray nozzles - as Skid Mark suggests. One check is to pull the tubing off of the plastic "T" where it splits to supply both sides of the windshield before it reaches the spray nozzle to determine if fluid is being pumped from the reservoir. If no fluid is being pumped, it is likely the washer pump. If the pump is operational, there is a non return valve in the line which may be clogged or the main delivery line may be clogged.
Had the same problem ..hose was pinched under the cowling below the windshield, note: be very careful when pulling the hoses off of any t's or l's , my car is 12years old and the plastic fittings are very brittle . also check that the screen inside the reservoir is clear where the pump pick up is.
The windshield wiper/washer is processed through the Body Processor Module which is fused on the driver' side fuse box by two fuses: #3 Wiper motor relays and #7 battery supply for solenoids, lamps, and motors.
The thought there is that if the wipers are working through their intervals, power should then be at the washer switch (button) to activate the washer pump. (unless the button switch itself is bad within the wiper control switches)
Skid Mark (11-16-2011)
I'm pretty sure there is debris at the bottom of the wiper fluid. I am able to disconnect he hose at the T and blow air down the tube creating bubbles in the reservoir. Whatever is clogging the system floats up and the washer fluid sprays well, but then it's clogged again a day later.
How do I unclog the bottom of the reservoir? It's hidden behind the wheel well and a panel in the engine compartment.
Thanks in advance!
CK
Thanks in advance!
CK
Chris,
I thought that reservoir didn't look familiar and then I read your thread title more carefully. This is XK8/XKR tech forum!
That being said, although the reservoirs are a different shape, the design is similar in principle.
The only way to completely clean the reservoir is to remove it and wash it out but you may be able to 'reverse flush' it like a radiator.
![Windshield washer not working-x350-screenwash.jpg](https://www.jaguarforums.com/forum/attachments/xk8-xkr-x100-17/71343d1480971253t-windshield-washer-not-working-x350-screenwash.jpg)
If you can disconnect the Screenwash Hose (item 10) and connect a pressure water feed to the Reservoir outlet, you can probably flush out the contaminants through the opened Reservoir Cap.
chris_kimble (02-05-2014)
Just fixed mine on my 01 XKR yesterday. After going through all normal diagnostic tests such as removing the pump and bench testing, checking for power to pump etc. Found pins on pump at plug corroded (hard to see), scraped corrosion off with a small file. Fine now. The plug is on top of the pump and can easily fill with water and not drain. The plug is not sealed, Be sure to coat with Vaseline or something similar.
I have a new (for me) 2001 XJ8 VDP. The windscreen pump works and lowers level in reservoir but nothing comes out of wiper jet. Further investigation showed fluid dripping from beneath the car in the transmission vicinity so I assume a hose is broken or loose. I have removed the right and center plastic engine compartment covers but cannot locate hose location(s). Unable to find diagram of windscreen washer hose routing - does anyone know? Thanks for the help. This car is replacing a 01 XJ8 destroyed by snowplow in upstate NY when there was 2m of snow in 3 days.
Robert
Robert
Well I did the tube replacement today and it is a lucky thing I bought the entire tube assembly since I found that the tube had been penetrated and the main fitting was broken (I am guessing that the servicing I did at a local mechanic a few months ago was actually responsible for this). Anyway the job went fairly easy. The toughest things are removing the wiper arms (MAKE SURE YOU HAVE A PROPER WIPER ARM REMOVAL TOOL) and trying to get that damn plenum drain tube back in place on the passenger side.
The first few times I tried out the washer the wipers moved but no fluid. Finally at the fourth time fluid came out (I assume the tubes needed priming from the pump).
Anyway I am attaching a couple of photos of the old assembly so you can see the makeup of the tube assembly. I placed arrows at the places that had been broken/ruined.
Doug
Doug
al_roethlisberger
09-11-2015 10:04 PM
philwarner
09-05-2015 10:05 AM
Chet Ramnarain (bozzner)
09-03-2015 12:21 PM
