Windshield Washers - RESOLVED
About to take car out today and even in the garage the windshield is covered in ash from the fires. Turned on the wash system and nothing? No fluid. Later tested system after making sure the reservoir was full, nothing? Wipers sweep, pump runs but no fluid delivered. Pulled off one wiper delivery hose, ran pump - nothing. Any ideas on what could be stopping the flow or is the pump impeller off?
Last edited by GGG; 08-25-2023 at 03:00 AM. Reason: Add 'RESOLVED' to thread title
Gained access to the pump by just turning the wheel hard over and removing the plastic access cover. Tapped the pump a few times with a small hammer and tried the system - it pumped fluid but only to the base of the windshield. Took off the plastic cover at the base of the windshield to find the T fitting had blown. Went to local hardware store and for $1.00 got a plastic fitting from a household plant watering system. Put it all back together and works fine! The failed fitting had probably put sufficient back pressure to stall the pump and a little tap freed it up. Cheap, simple fix.
The following 4 users liked this post by Rex:
