Wing Mirror Memory.
Wing Mirror Memory.
My left hand side mirror does not react to the memory button. I can set it. Try to store the new position in memory and nothing happens when I push the memory button except I do get the 'bong' noise as though its in the right place.
I can move the mirror with the joystick no problem. It will just not move to memory.
The mirror on the other side works fine. I can store its position fine.
I did try resetting the battery. It has had a new door mirror/window switch.
Suggestions?
Suggestions?
