Winter is coming in Cin, Oh what oil...
brgjag, because you have a 97 Jag, for winter, use of 5W30 will be the best choice. Thick enough to coat the surfaces well but not so thick when it is cold that it can't flow easily. If you had a new car, then that would be a different story. The newer motors have even tighter tolerances and require a different grade oil.
rsa760041
23
09-25-2015 02:33 PM
James007
09-06-2015 07:47 PM
