Wiring advice needed
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
Still looking for source for electrical parts. I have found my two major problems. P-123 pin 2 to em-27 pin 7 and p-131 pin 1 to em-81 pin 1. On both connectors I have continuity to rear of plug where wire goes in but checking at pin itself I loose continuity if I wiggle plug(bad crimp or pin). I'm looking for a source for pins and extracting tool. Any help is deeply appreciated as I have fought this for 6 months and finally found problem
Inspect the connector housing under a magnifier and bright light for a part number. It was made by 'AMP', which today is 'TE Connectivity'. Many AMP parts have tiny embossed part numbers.
If you can find the TE connectivity part number, search for it on Google. You should hopefully get a hit for the connector body on the TE website, and the downloadable drawing often references the associated pins and tools.
