Wiring in a second accessory plug-in?
Thanks for that info. It's also a more convenient location for dash mounted accessories than using the cigarette lighter harness.
Is there a 3-pin plug available from Jaguar or elsewhere to hook directly up to this aux connector?
The connector has standard .250" quick-connect blades...you do not really need to use a mating shell....just standard quick-connects from any auto supply store will do.
GGG (12-19-2011)
This auxiliary power socket information was provided by Jaguar and it might be what you are looking for http://www.jagrepair.com/images/Auto...owerSocket.pdf
A tidy soution but at high cost even by Jaguar standards.
How strange Jaguar should fit a power connector behind the glovebox and offer an additional glovebox outlet as an accessory.
![Smile](https://www.jaguarforums.com/forum/images/icons/icon7.gif)
SUCCESS! Thank you WhiteXKR and Reverend Sam. I was able to connect a female cigarette socket adapter into the wires you advised of and now have power for my new nav! I'll hopefully continue to have good luck finishing this project. I know I will be using the advice from this forum to make it happen!
Congratulations on getting it powered up. I bought a spare power source for the Magellen 5310 and tapped into the original GPS harness directly. I don't remember what the colors were, but I attached small electrical pins to the positive and neg from the GPS and pushed them into the corresponding positive (key on) and negative slots in the GPS harness, which allowed for no manipulation of existing wiring.
I bought two generic accessory outlets with the intent of installing in the glove box and trunk. Does anyone know off hand (by either position or color) which prong is the ignition based 12volt and which is ground. I want to ensure that whatever I hook up can't drain the battery when the car is off. Thanks.
#28
Red1bw (05-04-2012)
#30
#31
I didn't bother doing anything more fancy than use a couple of crimped spade connectors to fit over the earth and switched spades in the factory connector to get my DAB radio power.
Perfect. Thanks for whoever wrote the thread highlighting the relay no. 6 in the boot fuse box and it's purpose. The most difficult thing was finding where the actual accessory power socket was above the glovebox, it's kind of not in line of sight but tucked up inside at the top front edge of the glovebox appature. Obvious when you see it, whilst lying on your back with your head in the footwell!
![Icon Smile](https://www.jaguarforums.com/forum/images/smilies/icon_smile.gif)
WhiteXKR (11-02-2015)
Jaguar Forums Editor
Jaguar Press release
09-10-2015 05:08 PM
FS[Western US]: Jaguar xk accessories for sale
jfitzoz
09-07-2015 04:28 AM
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
