Wiring trivia
I had a Remote Top customer this week come across something unusual. He had a fairly early built 2000. Jaguar made a major wiring harness change between 1999 and 2000 XK8/R model years, which is why I have different versions for '96-99 and '00-'06. It looks like in early 2000, they ran short of the correct colored wiring, and used some available wire with color coded heat shrink tubing on the ends instead.
Here is a photo of what should be a brown/green wire, which is actually white/purple with brown/green sleeves. If you look carefully, there is another white purple behind it with red/yellow sleeves for what should be a red/yellow wire.
driver safz
09-26-2015 06:01 AM
