Won't go in gear, stuck in park
Hi Guys
I drove to work this morning, all OK no issues with the XK8. I have just jumped in it, car started OK but the gear selector won't fully engage in reverse ( although it will reverse if held there ) and I can't move the gear stick past reverse into Neutral or Drive. There are no warnings on the instrument pack.
Any idea what might cause this and is there a way around it. It feels like there is something stopping the gear stick from moving. The car is stuck on te carpark at work now.
cheers
cheers
No click heard with brake on but the brake light works. I also checked the brake switches with an ohm meter and they work OK, so I'm thinking there may be a bad connection between the brake switch and the ECU/Transmission controller.
I looked on JTIS and it suggested removing the Torque screw by the gear lever and overiding the gearshift lockout solenoid. that worked, so I am on teh move again temporarily. It's a good job I have a sense of humour and another car or I would be in tears right now.
Thanks for you quick reply
On late model XJs and XKs there is a shift lever bracket on the left side of the transmission. This device is prone to losing a mounting bolt and jamming the shift lever. Very easy to find and fix if that is your problem.
I'm not positive your car is set up this way but I suspect it is. Check it out.
Last year I had a screw come loose from my sun visor, I screwed it back in, and pinched the wire to the vanity mirror and blew a fuse, I did not know it and I couldn't get to shift also. I don't have access to my JTIS to look a the wiring schematics but I believe one of the J-gate sensors is on the same circuit, I'll try to look it up when I get the chance. I believe it was in the drivers side fuse block on the dash
piju1945 (10-18-2015)
Im having the same problem , But i do Hear a clicking noise on when i hit the breaks. What does this mean?
Same problem with vidor, stuck in park
Rlover
03-30-2016 10:04 PM
neruda
10-18-2015 01:19 PM
chatmanx
09-11-2015 07:17 PM
