Won't Start After Winter Shutdown
#41
Fuel pump replacement
I have the exactly the same problem, Make that tool that Avos suggests, that you can see in the you tube clip it’s a 20 minute job after that most of that is jacking the car up an getting a hook around each of the pipe to yank them free. I used a bit of welding wire and looped it around. You need to get a bit of light in the gap to see that the pipe has located into the connector then a sharp push to push back the securing wedges.
IanP
IanP
Charlene n John
09-28-2015 06:01 AM
