Wont start now
At times cylinder washing can cause this problem. Did you start and run your car for a short period of time to position it for the work you were going to do? When attempting to start the car does it sound a little different like spinning freely? You should make a few checks prior to your assuming cylinder washing is the problem and this link will help JagRepair.com - No Start I hope this helps.
![Icon Clapclap](https://www.jaguarforums.com/forum/images/smilies/icon_clapclap.gif)
As well as spark, battery and compression covered by Gus and Test Point, also check you're getting fuel through. With the temperatures we've had over the last couple of weeks, if there's any water in the tank or lines, it'll be ice.
Ha Ha GGG, I think mad as a hatter. Got home from work about 15-30 today nearly tee shirt weather after last week, floored the throttle put a booster pack on the battery hoping it was bore wash problems but still will not start. Maybe a bit of oil into the cylinders next and try again. Will post up an update with any news or which scrap yards its going to. LOL
![Icon Duck](https://www.jaguarforums.com/forum/images/smilies/icon_duck.gif)
After trying to start unsuccessfully a number of times, you're going to have to squirt some oil in the cylinders. I also like to warm the plugs in the oven on a baking tray to get them dried out. Not certain this is absolutely essential but it certainly winds my wife up.
Good luck. (if it doesn't go well, can I have first refusal on the rebushed upper wishbones?)
![Icon Lol](https://www.jaguarforums.com/forum/images/smilies/icon_lol.gif)
Never liked the idea of cranking an engine on dry, oil-starved cylinder bores. I just flash any unburned fuel with a lighted match at the plug hole. The HSE would probably have a fit.
![Icon Hide](https://www.jaguarforums.com/forum/images/smilies/icon_hide.gif)
Gus (02-15-2012)
Received 6,307 Likes
Take your ignition relay and swap them with another relay and see if that works. At times it just takes a little movement to get them seated properly. http://jagrepair.com/images/AutoRepa.../jagxk1999.pdf Look at page 35
It is in the no start procedure.
For relays, the two most likely culprits are:
1. Ignition: Driver's side fusebox at the end of the fascia - Brown
2. Engine Management - engine compartment passenger side fusebox in the bulkhead extension - Brown
There's a number of further relay / fuse possibilities. If you haven't got the Vehicle Care Manual you can download it from my MediaFile account. The full list is in the following thread:
https://www.jaguarforums.com/forum/x...-2003-a-67827/
There's several other circuits protected by the same type of brown relay. Gus advised swapping with a known good one. The headlamp ones are good to use for this as you can easily check they are working.
Good news , the car is now running, Gus you are a star thanks for your help, GGG many thanks for your help, also and your good humour. The thought of having to scrap the car and sell you my newly bushed wishbones made me more determined to get the thing running LOL. It did turn out to be a loose relay, must have come loose with all the hammering trying to remove the fulcrum pin on the front wishbone in order to remove rebush and put on the new springs.Thanks to all other people with help also. With hindsight I should have looked for a lack of spark earlier but it all seemed to point to borewash as the problem
