Is it worth the time and effort to.........
I have a new to me 2005 XK8. I will be transferirng some parts from my 2000 XK8 to the newer one and selling other parts. Here's my question. About 7 years ago I replaced most of the convertible top system. All the lines to the rams and latch, and, rams redone by Top Hydraulics. I will be removing the lines and rams from the 2000 XK8. The top on the 2005 works perfectly. Should I transfer the lines and rams to the 2005? It would be a lot of work but I'm not sure if by 05 the lines were not prone to leaking.
Thanks for the responses. It makes sense to keep everything for future use. I guess the only reason I was thinking of making the transfer now was that I had to take some of the interior apart on the 05. The electric seats don't work so those have been removed. Also, I will be installing the blue tooth module and wiring that was taken out of the 2000, so that requires the rear seats to come out to run the lines from the trunk CD unit.
royalumpire
10-10-2018 03:44 PM
twitcheyshane
06-12-2012 08:48 AM
