Would a 2001 XJR Differential fit?
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
What are the differences between an XJ and XK8 rear differential?
I want to eventually build a Rear axle with a Quaife and I can pull an XJ/XJR rear axle from the junkyard for cheap.
What has to be changed on an XJ rear axle center section to be used in an XK8?
Ungn (10-25-2016)
Ungn (10-26-2016)
