Would like to disable the Headlight washer - RESOLVED
Has anyone had sucess simply disabling the headlight washer? It has no postive use in my world and I'm tired of worrying that it will squirt a passenger or my dog everytime I use it.
Graham posted this in a similar thread recently (thanks Graham):
"The screen washers and headlamp washers have separate pumps in the same reservoir. One pump can fail and the other still work. The reservoir is behind the LH wheelarch liner."
This tells me I could just disconnect the power to the headlight washer, but wanted to run it by you before I create some kind of cascade disaster by doing so.
I should acknowledge that someone once posted that you can pull a specific fuse to accomplish this but I expect that no single fuse services the headlight washers so I didn't want to lose whatever else might be on that circuit. (do correct me if I'm wrong, a fuse would be much easier to pull)
Thanks for your thoughs,
John
John
Last edited by GGG; 01-13-2018 at 02:28 PM. Reason: Add "RESOLVED" to thread title
CE2 JAG (01-13-2018)
Interesting. I can't interpret page 14.1 other than F7 (Engine Compartment F Box) is solely for the powerwash pump. I would suggest the screen washer pump is supplied directly from the BPM, via either input 15 or 19 from F 5 or F7 ( Both Drivers side F Box). Although direct battery supply, they are switched through the ignition switched BPM ground wire (Output 5 from the BPM)
Edit: Later MY wiring diagrams differentiate between inputs 15 and 19 to explain that 15 is a Logic supply and 19 is a Motor supply, so it looks like 19, ie F7, Drivers side F Box is for the screenwasher pump
Interesting to read to the conclusion of the Fuse/Relay protection of this function.
The Drivers Handbook helps explain the BPM control of the frequency/delay of the headlamp washer when the screenwash button is pressed:
![Would like to disable the Headlight washer - RESOLVED-headlamp-wash.jpg](https://www.jaguarforums.com/forum/attachments/xk8-xkr-x100-17/131305d1465199070t-would-like-disable-headlight-washer-resolved-headlamp-wash.jpg)
I hadn't read this sufficiently carefully before and thought it was simply the headlamp washers operated at every sixth press of the wash/wipe button.
