Wow, changing a flat tire!
After cleaning my rear wheel sensors, I had trouble getting the tires back on. Aligning the studs with the holes is not easy with the tires being so heavy. I can imagine having a flat on a dark night, would be a challenge. For this car maybe a space saving spare would be more practical!
Don't forget that you can lower the jack height and avoid some unneeded tire lifting. Still having trouble? If you have a magazine somewhere in the car you can slide it under the tire you're trying to mount. Doing so will allow the tire to move around a bit more freely than a tire that is in contact with the highly tractive road surface. The other option has been noted saying that if you have a ton of time and don't need to be anywhere in the next hour or two - call roadside assistance,
RB
RB
