WOW soooo many codes on my 99 XK8
OK good people of this forum,Ive had relativly trouble free motoring all summer in My XK8,Then KKKAAHHBOOM ive had all these codes pop up on me.Could anyone tell me whats suddenly happened?thanks for your help.Shaun
P0301
P1316
P1144
P0351 and the usual P1000.
P0301
P1316
P1144
P0301 - Misfire detected, cylinder 1 Bank A
P1316 - Misfire excess emissions
P1144 - I don't see this code in my particular listing.
P0351 - THE LIKELY ROOT CAUSE - Ignition coil, cylinder 1 Bank A, primary / secondary circuit malfunction.
My guess...and I'm no tech...is that the coil has gone bad on cylinder 1 in bank A, causing the misfire and out-of-spec emissions being read. It may be that all you need is a new coil for that cylinder.
Good luck.
Good luck.
Coil
I had a similar situation - P0301 and P035X. Does the car run rough? I could easily feel the misfiring cylinder at idle. A Beck/Arnley coil fixed me right up. Check the plug bores for excess oil from a leaking gasket, it can cause a misfire, too.
My MAF sensor was acting up at the same time - that will also cause emissions related codes.
cylinder 1 coil went out on my car, all of a sudden, no warning. Don't wait too long, if the code popped up, that means 2 or 3 consecutive drive cycles logged a misfire. Its easy to change, just pick up a new coil at your local parts store (ok, call first, they had to get one from nearby at my store) and it'll take an hour, tops.
If your coil fails say...20 miles away from home, and it misfires all the way, that could very well be enough to damage your cat. I limped 2 miles down the road and changed it in their parking lot after have my coil cover off already at home, and a small ratchet ready to loosen the coil bolt in my front seat. Just be careful.
philwarner
25
06-26-2021 05:43 AM
