WOW - switched to LED headlights
Timeisrelative (11-07-2019)
I finally put mine in. It makes a world of difference, such a cheap safety upgrade. This is one upgrade absolutely everyone should do.
stay safe and have fun...
I do recommend one change in the instruction from above, instead up unclipping the retainer clip, just spread it open with a needle nose plyers, after doing that the bracket fit in without a problem.
" Detach one of the clip's connectors at the bottom (it just slips out), bend the clip to fit around the new flange, once you get it over the flange, reattach the bottom connection, then move to top and hook the top of the retaining clip in place."
ftypedreams
11-18-2019 07:21 AM
