X100 front parking sensor
Sorry to disappoint, but I have devoted my limited development time this past year to the X150 XK/XKR, but I will be back on X100 XK8/R projects soon.
XKRacer has said he has had some success with this kit on the XK8: Universal Parking Sensor | No Holes | Front & Rear Reverse Parking Sensors , but these have less range and are more prone to false signals than the factory ultrasonic sensors used in the rear. They also require manual triggering with a push button.
If you are willing to drill holes in the bumper and paint the sensors, there are many aftermarket ultrasonic sytems available...just have a look on ebay.
doowopfix (11-25-2013)
Any installation tips?
Thanks,
Jody
Daaah, Steve I was half asleep didn't twig the link.
Fitting is well explained in essence remove the bumper stick the sensor tape alone the length of the undone of the bumper link the wire to the module, find 12V connect, the hardest thing is locating a place for the on/off switch and routing the wire through the bulkhead. I find it works a treat and it doesn't mess with the lines of the car.
Off topic I also have a number of steve's products on my car and can't complain about any of them. The remote hood still makes me chuckle when I use it ;-)
There are also infrared systems that just tack on the bumper like this: but I have no direct experience with them. I suspect they work well for objects directly in front, but are weak in the corners. The sensor might also be susceptable to damage from of all things , low curbs!
PS: I am delighted the remote convertible top feature continues to please!
The pre-set timer is adjustable, and I believe I had it set for 30 seconds, just enough time to make the forward maneuver, before it automatically powered down
I'll try and dig up the information and post it on here ......
By the way, I did remove the Racing Green nose cone (which has the front parking set up installed in it) from my XK8 and have it in storage, and plan to fit it to my XKR sometime in the near future
