X100 Oil leaking from the torque convertor housing
Got oil leaking from the torque convertor through the lower access hole.
Assume the rear crankshaft oil seal or input shaft oil seal to the gearbox.
Cars a 1996 model with circa 80,000 miles and due an oil engine oil change.
Gearbox oil was changed circa 1,000 miles ago.
Any pointers or advise.
Assume this is a gearbox off job to fix, difficult or straight forward ?
O&DR (04-15-2020)
Ducmon
02-26-2017 01:45 AM
