Xenon Headlights leveling system - X100 XKR
Hallo guys... thanx for add. I'm new on the forum. I'm from Holland so I'm sorry for my English .... I'm still learning
I bought a XKR from 2002 from Califonia. We did complete renovation of this car and we are almost done, however there is still some little problems to be solved.
One of the problems is XENON headlights leveling system. It doesn't work .. I see no movement of the light while turning the ignition key. The xenon system is original btw.
How can i solve the problem? I have no idea where to find a level sensor and the lights module
Does any one had the same problem? The level of the right and left light is the same.
Thanks in advance for any help...
The fact that both sides don’t work seems odd to me. It’s my understanding, and I could be wrong, that each side was almost completely independent from the other, leveling sensors, motors, fuses, and I’m not sure on the controller. So if someone ore knowledgeable then me could both verify this, and think of a spot where they are linked, that would be your most likely culprit.
When end I first got my car both the light, and the leveler on one side didn’t work, but replacing the ballast fixed both. But that is not the same issue you have.
By the way your English was great in the first post. I seem to remember some other threads dealing with similar issues, a scan of the search function with “leveling headlight” limited to this sub may give you a place to start looking.
Here are some past posts that might help:
https://www.jaguarforums.com/forum/x...stment-146434/
https://www.jaguarforums.com/forum/x...02-xkr-171264/
BUYING JAGUAR X-TYPE OEM BI-XENON HEADLIGHTS WILL THEY WORK ON A 04-05 NON XENON HEADLIGHT CAR ?????
frombenz2jag
01-03-2024 10:58 AM
