XJ8 diff into XKR
Old 05-10-2021 | 01:46 PM
Robert Laughton's Avatar
Default XJ8 diff into XKR
A local shop has an '01 (A22555) XKR with a very bad diff. There aren't any XKR/XK8 diffs around, so we are looking at a sedan diff.
Searching here I found from Bob Gauff:
The Sedan diff will need the Jurid flange removed, the pinion shaft round Jurid extension cut off and the U-Joint flange installed to be compatible with the propshaft.
I had to perform this modification to get the 3.2 Sedan diff to fit the XKR and swap over the QUAIF 'internals' to fit Marks car.
bob gauff
So it sounds like this is possible. Both sedan and XKR are 3.06 I believe, but the prop shaft coupling is different, I get that.
Bob, what does " the pinion shaft round Jurid extension cut off" mean? I understand swapping the Jurid for the round companion flange.
Also, is getting pinion preload correct going to be a problem? Do you mark the location of the nut before removal?
Here is the sedan one:
https://parts.jaguarlandroverclassic.../brand/jaguar/
Thanks!!
Rob
Peter Brock
03-31-2021 09:48 PM
Willafizz
01-21-2021 02:41 PM
Jagman28
10-10-2015 07:25 PM
dannio636
11-25-2014 09:06 AM
Wayne Enticott
07-25-2013 05:55 AM
Quick Reply: XJ8 diff into XKR
