XJ8 to XK8 floor shifter
I read this last night and was sure someone would already have done it. It seems not!
The Gear Change Control isn't supplied as a single component but a check of the P/N's for the major parts of Gear selection Illumination Module (item 3) and the Housing and Sleeve (item 5) shows a close match between the XK8 and XJ8:
XK8
![XJ8 to XK8 floor shifter-xk8-gearshift.jpg](https://www.jaguarforums.com/forum/attachments/xk8-xkr-x100-17/95057d1480973652t-xj8-xk8-floor-shifter-xk8-gearshift.jpg)
XJ8
![XJ8 to XK8 floor shifter-xj8-gearshift.jpg](https://www.jaguarforums.com/forum/attachments/xk8-xkr-x100-17/95058d1480973652t-xj8-xk8-floor-shifter-xj8-gearshift.jpg)
I'd take the risk and go for it.
XK8
XJ8
metalmarty (09-06-2014)
Hi,
I have actually done this 'conversion'. Although the XJ8 and XK8 gear selectors are similar I found that the slightly narrower transmission tunnel of the XK8 made fitting the XJ8 selector mechanism tricky. I had to cut the metal side plate of the XJ8 down by removing a redundant bracket and cutting a 'triangle' of metal away to make the selector fit. Also a base plate hole needs enlarging as the mounting studs are slightly different.
cheers
cheers
Welcome to the forum kg7657,
XK8
Attachment 95057
XJ8
Attachment 95058
XK8
Attachment 95057
XJ8
Attachment 95058
Hi,
cheers
cheers
neruda
10-18-2015 01:19 PM
