XK 8 Air Conditioning-No cold Air
If it is at the top of the AC drier, it may be as simple as the O-ring on the line that goes into the unit. Most chain parts houses (not sure about that in DR) have assorted O-ring sets you can buy that will have a size to fit this line.
The bad news is that you will lose all your refrigerant changing it out.
snoxx (02-13-2014)
snoxx (02-14-2014)
There should be NO Bubbles with the Cap off. The Valve Pin in the Schrader Valve is probably leaking possibly due to a small amount of debris in the Valve. If you depress the Valve Pin and release it rapidly several times it may start to seal ok again.
I this exact problem on my 1999 Acura and depressed the pin several times to clear it.
2008xk
08-19-2021 10:54 AM
