xk engine decarbonizer
Received 9,010 Likes
XKCoupe (12-20-2012)
A well cared for modern engine with no "issues" should not carbon up, even after 70 or 80 thou miles. At least that's been my experience.
My point is, consider TerraClean if you need it but not as a prophylactic. If you do have a carbon problem, try to fix the underlying cause in conjunction with whatever decarbon procedure you select.
OkieTim
09-08-2015 04:48 PM
