xk grill question?
There are plenty of polishes but it is hard work to get into all the overlaps to clean, easiest and quickest I have found (possibily cheapest too) is to use a small wire brush.
You can often get them at hardware stores, a bit bigger than a tooth brush, you can use something a bit larger for the center section but for the edges you will need the smaller.
Good luck
Good luck
texastim (12-22-2010)
FS[SouthEast]: 2008 XKR front bumper for sale
Sublyminal
09-15-2015 06:32 PM
doctordeuce
09-12-2015 08:30 AM
