XK8 1997 Audio System has "Popping" Sound
Old 04-06-2016, 02:01 PM
pilot435's Avatar
Default XK8 1997 Audio System has "Popping" Sound
Hi, My 1997 XK8 has a loud "Popping" Sound from the audio system when the engine is running. Sounds fine when the engine is not running.
Has any one else had this problem?
Thanks in advance.
GE
Old 04-06-2016, 04:06 PM
DaveInVA's Avatar
Check the 2 molex connectors on the power amp under the top pump. They get tarnished and doesn't take much vibration to make them go flakey.
Dave
pilot435 (04-16-2016)
Old 04-06-2016, 08:26 PM
pilot435's Avatar
Will do. Thanks
GE
Old 04-07-2016, 03:11 AM
GGG is offline
Received 16,860 Likes on 12,186 Posts
Does the frequency raise with engine revs? If so, suspect the alternator suppression module or harness.
pilot435 (05-01-2016)
Old 05-01-2016, 09:08 AM
pilot435's Avatar
The frequency or rate does not change with engine RPM. In fact, rather strangely, it does not change any at all with engine RPM (volume, character, etc.).
Regards
kenatofc
03-20-2016 07:08 PM
BillC
03-16-2016 09:37 AM
winstonwu91
03-15-2016 08:39 PM
Harry Dredge
03-15-2016 03:44 PM
Jasper Holland
XJ40 ( XJ81 )
03-12-2016 03:13 PM
Quick Reply: XK8 1997 Audio System has "Popping" Sound
