Xk8 1999 auto 4.0 ltr.
Received 2,380 Likes
I'm intrigued that the dealer elected just to replace the TPS. Although the dealer doubtless has better contact with Jaguar than we as members of the unwashed masses, as far as I know the official line is that it's not available separately: the whole throttle body must be replaced.
Mike
To be honest Carl your friend has been very foolish in going to that particular franchise in the first place. Given the opportunity they will continue to replace components until the car is fixed, all at the owners cost.
It would have been prudent to have found a respected and recommended indy rather than these modern day highwaymen.
It's a very expensive lesson but he needs to get his car away from them.
He was in the same situation of it going into Limp Mode, Restricted Performance, Traction Control and ABS warning. This was the same as when the existing ECU and Two Upstream Sensors that was not changed. So I myself and my friend cannot see why they fitted the new ECU and Sensors whilst it made no difference.
Its this TPS that looks like it have corrected what was wrong for over the period of in total about 6 months. Please send me your thoughts if you wish. Many thanks.
But you said previously that when they changed the ECU and the o2 sensors it ran fine for 200 miles:-
You can understand why Stratstones might think they had found the problem if it ran ok when they returned the car.
The only way to prove whether the ECU was in fact faulty is to refit the old one - does your friend still have it?
As of previous posts, A new ECU and New Upstream Sensors were fitted in the first two weeks of Stratstones having the XK8 1999. However, the car was run by them and then returned to my friend. My friend run the car to just over 200 miles without any problems. Then on Monday 28th it went into Limp Mode again and Stratsones had it back on Wed 30th.
These issues was the same as with the existing ECU and O2 Sensors anyway. When they then put in a New TPS on the 06/01/2016 its running as it should with no problems. To me they new this from the start of fault code P0121 and P0123 being the TPS, they wanted more money to put on the parts that was not needed. Please if you wish send me your thoughts. Bye for now.
Without the old ECU its going to be very difficult to prove that it was not faulty - plenty of people on this forum suggested the ECU as being a possible culprit for the problems you were getting, so its not unreasonable to have changed it. However, from reading your original thread again it looks like Stratstones did the following:-
1) Replaced the O2 sensors twice
2) Replaced the ABS module twice
3) Replaced the Throttle Body (once)
4) Replaced the ECU - which got the car running again for 200 miles over 2 days
5) Replaced the TPS
It does seem that every time they have replaced something, the new one also didn't work. In the case of the Throttle Body, is it correct that the TPS on the new Throttle Body was also faulty?
5) Replaced the TPS
+1 Kreyszig
To repeat: as far as I know the official line is that the TPS is not available separately: the whole throttle body must be replaced.
Wouldn't a surcharge on the ECU indicate that the supplier intends to rebuild it? I doubt Jaguar is in that business.
Just doesn't sound kosher to me...
Bottom line is the car back in service so at least the desired outcome.
M
#31
Stratstones replaced the 02 Sensors once, the ABS was not changed by them, the TB was never changed by them, it's the original one, the only items they changed for new was O2 Sensors, ECU, and TPS. To me if the TPS was changed at the start it would run as it do now. Perfect.
No one can help you if the facts aren't clear.
#32
An after market new TPS on Ebay is £32.50, a new one that is a genuine one form Jaguar made by Denso is £92.50. Hope this info helps you.
#33
OK, Listed below is exactly what Stratstones have only done.
1) New ECU.
2) 2 x New O2 Sensors.
3) New TPS.
According to the garage that had the car previous to Statstones, he mentioned that the ABS Module was reconditioned, the TB was reconditioned, to me its a load of baloney, the reason for myself and my friends verdict is because the car was running no better ( ABS Warning Light, Traction Control, Restricted Performance etc.) to how it was prior to these items being reconditioned. (No Change)
When Stratstones installed a New ECU and 2x New O2 Sensors it was running OK for approx 200 miles and then back to square one again. So what was the point of changing any of these items that did not put the car to run as it should without a fault.
On the 05/01/2016 there was a New TPS fitted, on the 6th when collected the car from them, its now for the last 10 days to today's date running as it should with no faults whatsoever. Even a Diagnostic tool is showing nothing at all of fault codes. All that's been carried out by Stratstones has a 2 year Warranty for parts and labour, this is something that puts my friends mind at rest for now.
1) New ECU.
3) New TPS.
#34
#35
So in summary, after your friend power washed the engine compartment and damaged the electronics, he took it to various mechanics who swapped various components without success until finally your friend took it to Stratstones who fixed it and gave him a 2 year warranty on the repairs?
He should really be grateful that he didn't have to scrap the car and I hope he has learned his lesson that power washers and engine compartments don't mix.
#36
Great thing is I don't have to post anymore info on here as its all done and dusted. My friend has been so grateful that the replies on here that I passed to him have on times helped matters to ease his mind.
At his age now of 84, there is not much point in him owning a PC to do his own research. God bless you all. Happy New Year.
cjd777 (01-16-2016)
#37
![Thumbs up](https://www.jaguarforums.com/forum/images/icons/icon14.gif)
This should have been changed from the start and all else left alone that did not need replacing. That,s some garages that likes more money, but certainly not all are the same.
#38
I am hoping that strastones is a dealership or authorized jaguar repairshop if so look up who the president of customer service for jaguar {or vp}and call him directly about your issues about unneeded parts to correct the problem. if no satisfaction is found then tell them that you plan on calling the local tv stations and papers big companies don't like bad press.
#39
Sad as it is, I don't order my friend @ 84yrs young not and what to do. Cheers and take care.
#40
