XK8 1999 Strange leak lower front passenger
I'm guessing it's power steering, which these cars use ATF fluid in place of. Check that out, while steering, listen for any grinding sounds. IF you hear something, then you can infer your power steering reservoir has been dried up. If it is, add more ATF fluid and go get that fixed.
On a side note, #4 has a point. Is your coolant fluid the orange stuff or the green stuff?
And I missed the obvious, look at your reservoirs and see which is low on fluid.
My coolant is green.
Thank you for the hint! My mechanic said it might be the oil cooling system that is leaking but I don t really know if his guess is correct and wated to have different opinions on the issue
MC36
US Lower Atlantic
09-01-2015 08:34 PM
