XK8 2001 front bonnet will not release to open
Try having someone push down on the side that is not releasing to relieve pressure as you pull the bonnet release handle. If the latch is just stuck this may allow you to take off get enough pressure to open. May take a few attempts. Then lube and readjust the bonnet latches. Hope this helps.
Mike
Mike
is the cable still attached to the release lever? you saying you pull the hood handle on 'passenger side' throws me. is your car a RH car?!!! American ones have hood release LEVER on drivers side.
maybe im missing something in your question.
anyway, hopefully it's just the cable 'end ball' has broken through the lever. it's just plastic.
good luck with it.
I read it again, and you're maybe talking about the convertible TOP. different ball game than I was thinking.
good luck with it.
99xk8guy
06-05-2023 06:28 AM
