XK8 2002 stereo trouble - RESOLVED
Hi all.
Sorry if had all this before but my xk8 stereo all works as normal but no sound🤔
I had someone out to look at it and was told it's the radio.so I have got the same radio cassette type and model fitted it and exactly the same?
Now I am no tech wiz. And he tells me the amp is in the stereo on this type?
He said there is no other amp.
I did have a look above the cd changer by pulling back the panel a bit and could not see a amp above the changer.
Has anybody any idea please.?
So so far I have paid a man to come a diagnose it as a fault with the stereo.
And purchased a replacement and still nothing.
Everything works just no sound 😖
Last edited by GGG; 07-10-2017 at 07:45 AM. Reason: Add "RESOLVED" to thread title
Tgk9 (07-06-2017)
Hi all.
Tgk9 (07-06-2017)
Thanks for replying
Very confused 😔
Just to be clear - when you say "works as normal" that is .........
Lights come on on radio panel.
Aerial (antenna) goes up (and down) when switched on and off.
Cassette / Radio / CD player all function as they should.
Fader / balance / Treble & Bass etc buttons all function as expected.
You don't have tweeters on the doors (inside) near the rear-view mirror.
But ................ no sound AT ALL from any speakers on either radio, cassette, or CD ?
Yes ?
Yes ?
Tgk9 (07-06-2017)
Yes ?
Yes ?
l had much the same trouble with mine but only when l switched the head unit on after the ignition. If the head unit was on when the car was last used it would work fine when car was next started. I know it sounds odd and took a bit of luck tracking down the solution.
Solution was to close up very slightly all female terminals in the plugs so better contact was had with their matching male pins in the sockets on back of head unit.
It seems that some power and display functions are powered separately to audio function via several power inputs.
The following 2 users liked this post by baxtor:
Orthodixie (07-06-2017),
Tgk9 (07-06-2017)
Orthodixie (07-10-2017)
that sounds like a possibility I have pressed all the buttons to see if it changes anything.
but don't know how or if on mute?
tried the phone bits on the stalk and stereo still no joy.
Mute is triggered by grounding. Your 2002MY will have the 14-Way telephone connector under the centre console even without the phone installation:
Telephone Socket Pin Numbering.pdf
Pin 6 (Blue) is for mute.
The following 2 users liked this post by GGG:
Orthodixie (07-10-2017),
Tgk9 (07-07-2017)
Stereo trouble
Ok here we go again. SORRY all.
Right I had a thought disconnected the battery. When I reconnected i set he radio code all came on and sound yay.
But only on for about 30 seconds then back to no sound🤔
This happened twice. With my original radio. So presume the other 2 I have will do the same.
Seems very strange. I was stationery too.
Tried various different people all saying not sure.
Can anybody give me a clue please😞
Like I say no tech wiz but I am trying.
Xk8 stereo trouble.
First of all I would like to thank all that tried to solve my problem.
I managed to get stereo working and cut out again a few times no sound
When I turned up the volume a bit.
I took out a speaker that had a different sound slight distortion.
And all seems to be working ok now. Minus a speaker obviously.
Plugged it back in to confirm it was the speaker and went mute again.
So that seemed to be the problem.
Even though I did get auto electrician to check it all and said speakers had feed to them.🤔
I only managed to get terror working by disconnecting the battery.for anybody with the same problem.
THANKS ALL
THANKS ALL
The following 3 users liked this post by Tgk9:
Tgk9 (07-11-2017)
lovemycar1 (07-22-2017)
