Xk8 brake switch fix
I have been having problems with my recently acquired 98 xk8 brake pedal switch. At first I was getting the usual failsafe/cruise control issues but pretty soon my brake lights were only working periodically. I planned on replacing it but while I had it out I figured I would open it up and try to see what was wrong. I couldn't see anything noticebale and it all looked clean. What I ended up doing was resoldering every connection on the board. I reinstalled switch and everything works as it should now. Hopefully this helps someone.
. What I ended up doing was resoldering every connection on the board. I reinstalled switch and everything works as it should now. Hopefully this helps someone.[/QUOTE]
Good for you mate. I too have a 98 and am sure to face thos someday. Which board (and where is it) dod you work on? Thanks
dsjohn
02-15-2016 07:55 PM
