XK8 cam flats do not line up!
I am doing my secondary tensioners , intending to use the locking tool. As you can see my cam flats do not line up. The car runs great and there is no slack in the chain. I just assumed the flats would line up. what do I do next? Thanks, David. ( this is a repeat of the timing parts thread)
Not wanting to perpetuate the hijack on the other thread
thought I'd offer my opinions here.
I used the zip-ty method when I changed my tensioners, but I'm certain the flats on my cams lined up, and I'm almost certain I rotated the engine through at least one revolution during my job and noticed that they lined up each time. Edit - However, it wouldn't hurt if you rotated the engine through a revolution to be sure yourself.
I've read that the VVT solenoids work to change the timing away from the "relaxed" state that we see when we the engine is not running. So it's normal that the flats should line up when we pull the covers. I don't know the extent of the timing change when the VVT solenoids fire, so it's possible that you might have a stuck solenoid? If so, it would be the first I've read of that in my three years on this forum. Still, worth a look.
Looks like you're going to have to go through the steps to adjust the timing now.
So, if you think the engine is running great now, just wait until you complete this job, you're going to see an imprevement!
Best wished to you, keep at it.
Steve
![Icon Nut](https://www.jaguarforums.com/forum/images/smilies/icon_nut.gif)
Steve
I just tore down my engine, two days ago, and the flats lined up on both banks at the same crankshaft position. My car is an XKR and I don't have any VVT on my intake cams, so I cannot speak to that aspect. I didn't see anything in my version of JTIS regarding this.
Do you have the locator pin in place of the Crankshaft Angle Sensor at the flex plate? If so, that is where the flats should line up.
Is this on both sides? If you have not checked the other side take off the valve cover and check it. All four should be flat at the same time. The one that isn't has skipped a tooth. If it is the intake I suppose the VVT could be stuck as others have mentioned.
If they are bad on both sides then somoene retimed the cams. Either someone purposely changed it or made a mistake.
Received 6,330 Likes
I think you've probably found the problem. Timing any engine should be done in the direction of normal rotation. There will be slack on the non driven side of any chain. Rotate your engine clockwise and then check the timing - let us know how you get on.
There must be no slack on the driven side of the timing chain when tightening the securing bolt - not sure whether you have the crankshaft locking pin as well as the cam locking tools? When you have refitted the camshaft gear take off the locking tools and check and double check the timing taking care only to rotate in the normal direction i.e.clockwise. If everything lines up and the cam gear is correctly torqued you should be good to go.
JITS says that you should only rotate the engine clockwise, as the timing chains could bind.
The Intake Cam is driven off the crank and the Exhaust Cam is driven by the secondary chain off the Intake Cam.
You will need to use the sprocket tool with a breaker bar or pipe attached to it to tighten the bolt the required amount. I had to really lean on mine to get them apart.
Charlie
Charlie
Well I was going to ask why my timing chain is so tight. I am on the left side and have the locking tool on and the exhaust sprocket bolt off but the chain is too tight to get the sprocket off. I wonder if I have bound up the chains. any Ideas on how to unbound the chains? What if I put it back together and turned the engine clockwise until the flats came around again?
Dickie_L_J_O
09-13-2015 07:44 AM
