xk8 center dashboard light replacement
Changing the dashboard lamps is one of those unfortunate necessities of car ownership.
There is a nice YouTube video on this subject, but for those of you wonderful XK8 owners who like a procedure (as I do)... here you go:
Replacing Jaguar XK8 Dashboard Lamp Bulbs
Michael Herman
October 20 2012, redone July 11, 2014
Buy bulbs in advance of this procedure. You will need
4 Large bulbs: Sylvania 2821 LL or Philips 194,
4 Small bulbs: Sylvania 2723 LL or Sylvania 37LL or Philips 37.
I found the Sylvania 37LL lasted about 4 years. I therefore replaced the Sylvania 37LL and 2821LL with Philips 37 (=37LL) and 194 (=2821LL) on July 11, 2014. Cost is $5 for 2 bulbs, at Pep Boys, a nationwide US chain.
Tools: 7mm and 8 mm sockets (shallow sockets are fine) and a socket wrench to drive them. You need a 10mm wrench to disconnect the Battery ground terminal. You also need a long magnet (such as a magnetic screw retriever tool common in auto repair work) to prevent screws from dropping. Philips #2 screwdriver. The entire procedure will takes about an hour the first time, or could be done in about 35 minutes with practice.
Video Jaguar XK8 Instrument Cluster Bulb Replacement - YouTube
Step
Activity
Accumulated Time
Use the button on the left of the steering column to move the steering wheel UP and out.
0 min (start)
2.
1 min
3.
5 min
4.
7 min
5.
6.
7.
Then turn the steering wheel knob control to OFF so it does not park back in when you open the door.
8 min
8.
9 min
9.
KEEP THE DRIVER DOOR OPEN or retract its glass down so the doors will open and close without power.
10 min
10.
12 min
11.
12.
14 min
13.
16 min
14.
19 min
15.
16.
22 min
17.
24 min
18.
30 min
19.
20.
21.
40 min
22.
You rotate the display dashboard panel (which has the light bulbs) facing downward, above the steering wheel, so it can be pushed into the cavity. Push it back in and rotate it to face forward, reversing the way you removed it.
Before you secure its 4 copper colored bolts (with 7mm heads), be sure that you pull the wiring for the black connector above the electronics panel, so it can be reconnected to the front woodgrained panel.
After you put the 4 bolts (7mm heads) in, re-install the triangular vent cover to the left.
Then install the electrical connector for the trip on the top right of the woodgrained dashboard cover, and slip the two large top tabs under the top of the dashboard. Then screw down the 2 philips head screws.
Then slip the top of the knee "bolster" into its top groove, and re-attach the valet switch on its left. Then install the 2 copper colored bolts (8mm heads).
Finally, reattach the battery terminal, and put its battery panel back on top.
All done...
About 60 min
thank you
Bill Jacobs (03-12-2022)
have you checked to see if they are already marked from the manufacturer ?
like in this photo which shows Sylvania bulbs pre-marked:
They came from Amazon, no availability issues.
Otherwise you can just connect wires from any battery, 12v or less, to the bulbs. It will only light up when the correct polarity wire is touched to the bulb. A 9v square battery works well .
Markmbaha1 (11-08-2021)
Mark
