XK8 Central Locking
Hello,
I have been experiencing the dreaded cycling problem with my 2004 XK8. I press the key fob to unlock and it unlocks, locks, unlocks, etc 4 times before getting bored.
Extensive searching revealed the likely causes to be fuses or microswitches.
I have replaced both fuses (1 in the boot and one in the fascia) and the microswitches in both the door mechanisms.
Sadly, nothing has changed.
Where does that leave me? Is it a replacement electronics box?
Which one?
Any advice gratefully received.
Cheers,
John
Which one?
Cheers,
John
Received 1,796 Likes
Welcome John, I guess the first thing we ought to do is get you to the XK forum, this is the XJ, lets see if we can roust up a Mod. But in the meantime, I'm sure someone there will ask your battery condition. One thing both cars can suffer from is when the battery gets low, electrical gremlins come a crawlin'. Be sure to check your cables for any corrosion, if there is, replace it.
Don B (08-25-2017)
Check your ground points, especially the one in the trunk. Here's a link you'll want to put in your favorites.... JagRepair.com - Jaguar Repair Information Resource ...and be sure to review your Sticky's in the XK forum. Folks have put in a good effort there to make your life a little easier for many common repairs and TSB's.
Don B (08-25-2017)
Received 13,007 Likes
Don B (08-25-2017)
Thanks, everyone, for the useful suggestions.
Sadly, none of them has helped.
So far, I have replaced the microswitches in both door locks, replaced the fuse in the boot and the one in the dash and charged the battery for a whole day. I did check the microswitches operated correctly before I refitted the locks, too!
I suppose I could replace the battery anyway, but it's a lot of money if it doesn't help!
Are there any other avenues left to explore?
John
John
Hi John,
The computer modules in these cars are hard on the batteries. I had both the door lock cycling problem and the curse of the dropping window.
The battery started the car without a problem, but even on a trickle charger it would not hold enough of a charge to keep away the electrical gremlins.
A new battery was expensive, but it fixed the problems. I still keep it on the trickle charger if the car is going to sit for a week or more.
Stu
Stu
Don B (08-29-2017)
Have you looked at "maintaining" your battery. Take a picture of any stickers, and look the battery up. If it is not AGM or "maintenance free", and you can confirm this is a conventional "low maintenance" acid-lead, you need to pop the covers off and top off the cells with distilled water. Typically gets you a fraction of a Volt, but could be enough of a boost, at least for a while.
Best of luck, keep us posted.
