xk8 code p1797
xk8 code p1797
Ladies and gentlemen, I need some help on my 1997 xk8, I am getting the check engine light and every once in a while i get the stability/traction control fail messages and also the gearbox fail message. There is no actual problem with the car when I drive it around town, I would just like to figure out these troubles before it progresses to something bad or it causes me to get into an accident. I plugged in a ebay obd 2 code reader and got the code p1797. I looked at previous threads and did follow some advice. I replaced the battery with a new one, reset the ecu, and checked the connections at the ecu and tcm for wear with no avail. I do not know how to approach this problem next. Your help will be gladly apprecaited, thank you.
P1797 Neutral Switch Circuit Malfunction
Read more at: Jaguar Check Engine Light DTC Trouble Codes
Copyright © OBD-Codes.com
Ali, this is all I could find and really not sure where to go from here.
P1797 Neutral switch malfunction.
Wayne
Wayne
ali123 (08-24-2014)
Oh the error sorry I forgot to mention the error means CAN TCM/ECM Circuit Malfunction, and when I said I checked the connections at the ecu/tcm I mean I simply looked at them, I did not do anything but I heard some people use a volt meter to check the connections etc... Should I do that or any idea what I should check next? thank you
philwarner
25
06-26-2021 05:43 AM
