XK8 Convertible - Manual Release with Hex Key
Alan, I couldn't find the name, but I bet you can find or fashion a replacement.
Problem will be color. I was about to attach the color combinations document when I realized that's ineffective. You'll be spending way too much time hunting down some rare color like Antelope. . . With no luck.
Here's the shortcut. Just take a piece of the same color to home depot. They can match the color for a few bucks!
Example: when I had to touch up the steering wheel, I pulled the triangular vent from top left of dash. Same color. Worked great!
I forget if the blank plug you referenced is same color as seats or as the secondary accent color. But its just a 1cm flat plastic plug right?
John
John
Received 4,341 Likes
Johnken (06-16-2023)
jagxkrtoofast
03-08-2010 12:07 PM
