XK8 convertible top rubber seal
Old 03-03-2018, 08:58 AM
Dercent's Avatar
Default XK8 convertible top rubber seal
Does anyone know how to remove the rubber weather seal on the convertible soft top on the passenger side, there are 3 pcs. I tore mine real good, make a hole in it, have not taken it off yet, but have located another one, it looks grooved and maybe glued in, don’t know, before I tear into it wonder if anyone else has taken a pc. Off and replaced it. It’s the pc that is 15 inches long and cut at end at about 45 degrees and fits into the front pillar piece. Thanks Dave in Tampa
Old 03-03-2018, 09:29 AM
avern1's Avatar
Received 1,319 Likes on 1,004 Posts
It is locked into each side by a lip forming a groove. When I replaced the passenger front I removed the fasteners and just pulled it out. To install just place one side in and then you can squeeze it and insert the opposite side.
No glue needed.
Old 03-04-2018, 11:25 AM
Dercent's Avatar
I did not see any fastener on the gasket/ weatherseal just a separation where the pieces ,meet together, so I am hoping that the pc I am taking off the other car just pulls out when I squeeze it.
Old 03-04-2018, 01:11 PM
avern1's Avatar
The first one front has fastener the next 2 do not. Sounds like you are working on the center one. Just pull it out. Install the new one as I posted. If you need to re-position (to adjust) you can use a push with one hand pull with the other hand to move it.
volkris (10-20-2019)
Old 03-04-2018, 03:48 PM
Dercent's Avatar
Yes it is the middle one ok will pull it out believe I will take all the pcs from both sides and hang onto
jagosaurus
11-26-2020 06:05 AM
Jandreu
01-17-2016 12:35 PM
280zx-turbo
10-16-2015 04:48 AM
POCCNR
08-02-2015 11:21 AM
1morecarplease
04-10-2012 10:19 AM
Quick Reply: XK8 convertible top rubber seal
